PC specs/ Coolermaster Centurion 531
4 Dec 2005
Hi
Just about to purchase all the new bits for a home computer. I have been through the read me page on this forum and am satisfied that all my components complement each other. I was just wondering though if anyone could have a quick look as I've never put one together before.
Also I have a case that was bought a few years ago (Coolermaster Centurion 531) http://www.overclockersclub.com/reviews/coolermaster_centruion_531_chassis/ , will this be ok to use for the specs?
AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-238-AM
XFX ATI Radeon HD 4770 512MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showproduct.php?prodid=GX-133-XF
Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel (TWIN2X4096-8500C5C)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-192-CS
Asus M4A785D-M Pro AMD 785G (Socket AM3) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-357-AS
Western Digital Caviar Black 500GB SATA-II 32MB Cache - OEM (WD5001AALS)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-245-WD
Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 Power Supply - Black Nickel
http://www.overclockers.co.uk/showproduct.php?prodid=CA-022-AK
Thanks a lot :)
Will
ps. should i get 64bit windows 7 or 32 bit?
All should work together, cant say anything about the case thought because i dont know anything about it. Have you already got a DVD Drive + OS?
thanks will. yes i am using the upgrade offer for students to get windows 7 not sure whether to get 32 bit or 64. is it just drivers which are unique to 64bit and will old software work? yes i have speced a sata LG dvd burner, just didnt think it would be too relevant
