ok so made a post few weeks ago and now have settled on the specs, after some very helpful advice
want to get a few more recommendations
ga-z77-g3h
i5 3570k
r9 280x or 290x if i have the extra cash at the time
750W Corsair HX750 or maybe a ax1200 pro if one comes up s/h
8Gb ram
Win 7 x64
bluray and dvdrw drives
not fully decided on a case, but one that can accept a top mounted 240mm rad
going for air cooling at first. and then will run a h100i on the cpu and h90 on the gpu , either using the red mod or the nzxt adaptor. either way ill use alloy heat dissipators and will have a bottom fan pointing up.
now running xfire/sli my board is 1 x x16/x16 pcie 3.0 and 1x x16/x4 pcie 2.0
will two 280s run at x4/x4 or x8/x8 different sites state diffrent things, or will one 280x or 290x be more than enough.
am i set to go on these specs? would love to play as best with high settings and maybe ultra on 1080p 32" screen, altho i may jsut get a 26" as 32" is a little to big.
games are likley to be
battle field, need for speed, latest cod title, maybe crisis 3.
cheers guys
ga-z77-g3h
i5 3570k
8Gb ram
Win 7 x64
cheers guys
