- 20 Feb 2014
- Sydney, Australia
Hey there OC,
Hoping someone might be able to help me with an issue which has only started happening with my PC since I purchased an Acer CB280HK 4K monitor.
I love the monitor and resolution, but I use Displayport in order to gain the 60hz signal at 4K as required. However, some days when I turn the PC on for the first time that day, my PC resets itself after a few moments and gets stuck in a boot loop and will not start up. I have to turn off the power supply switch, unplug the Displayport cable, and then let it boot up and plug the Displayport cable back in after I know it's loaded to Windows log in screen.
Just wondering if there's any settings on the monitor, BIOS etc that you know of that I could change to sort this out? It works fine with HDMI on this monitor and my old one - my old one doesn't have a Displayport connection to test that though.
One thing I've noticed with using this monitor/Displayport is that the PHASE LED lights on my mobo are staying on after I turn off the PC for the night. I think this might have something to do with it, possibly with my C states in BIOS, but I have a couple of things I like charge from USB ports overnight. I guess I could live without that though if it meant this would be fixed! But from what I've seen online, it looks like some weird compatability issue with Displayport and my motherboard and may not be able to be sorted.
But if you guys know of anything I would be very appreciative! I'm very sorry if this has been discussed somewhere here before but after a bit of research I couldn't find anything.
My specs are up to date in my sig if it helps any!
Cheers guys,
Adrian
Cheers guys,
Adrian
