- 23 Jun 2004
- Blackburn
So last night I turned on my PC. Specs are in sight below. All was fine, logged into Windows but after a few minutes my monitor went to standby and wouldn't wake up. PC wouldn't restart or turn off with the power buttom so had to turn off at the psu. Since then it won't post and debug led stops on either CPU or RAMw depending on what I've tried. Eg. I unplugged and reconnected CPU power and then the led passes cpu but stops at ram. I've reseated CPU and GPU and tested RAM in another PC. RAM is fine. Tested with another PSU but just get the same issue. I don't have a way of testing CPU or motherboard unfortunately.
I'm leaning towards the motherboard being at fault because it doesn't seem to know whether the RAM or CPU is st fault, either though the RAM is fine in another system.
Any thoughts?
Any thoughts?
