PC surround sound + xbox 360
Depends on the setup?
Your post is slightly vague, do you mean you want the PC and the Xbox to use the same surround sound set? What connector do you need to use for the surround sound on each? Which amp/speaker system do you have?
There's almost certainly a solution though. :)
If they're both using optical cables to go to your surround, you'll just need a toslink switch.
Basically I don't know all that much about sound systems.
My PC speakers are creative 5.1's with normal red/blue/green (or whatever), is there a way of using this sound setup for the xbox 360?
to answer your question, the only way to get surround sound on xbox is to use optical. therefore with your creative speakers you have at the moment, you cannot get surround sound from them.
If I used the official HDMI cable, it has the extra audio connectors. .... so is there a convertor or somthing I can buy to get sound out of my speakers?
What about an amplifier? If I connect through that can I get surround sound?
