pc to build
25 Dec 2007
I am going to buy all the parts tommorow or the day after, i hope all goes well after that. Could you double check everything for me and make sure that everything is compatiable or that i haven't missed anything out, i am going to be spending quiet a lot so i thought I could ahve some double check it? So there is nothing else to get besides what I’ve got? Just need a screw driver to put everything together? I've setup a pc in the past, but that was like 4 yrs ago and i used the stock AMD fan, i didn't take noise into consideration nor did i care.
Auzentech X-Plosion DTS Connect 7.1 Sound Card - Retail
Samsung SpinPoint T 500GB SATA-II 16MB Cache - OEM (HD501LJ)
Western Digital Caviar SE16 320GB SATA-II 16MB Cache - OEM (WD3200AAKS)
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
Asus GeForce 8800 GTS 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Corsair VX 450W ATX PSU (CMPSU-450VXUK) Corsair VX 450W ATX PSU (CMPSU-450VXUK)
Samsung SH-S203NRSMN 20x DVD±RW SATA Dual Layer Lightscribe ReWriter (Beige/Black/Silver) - Retail
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
Dell E228WFP 22" Widescreen LCD Monitor - Black
Logitech Cordless Desktop MX 3200 Laser - Retail / Logitech Cordless Desktop Wave - Retail
Antec Solo Quiet Mini Tower Case - No PSU
Thermalright Ultra-120 Extreme CPU Cooler (Socket AM2/LGA775)
Scythe S-FLEX 1200RPM Ultra Quiet 120mm Fan - 3/4 pin
Zalman Fan Mate 2 Zalman Fan Mate 2
Sharkoon Silent Eagle 1500 92mm Fan - 3/4 Pin
Scythe Kaze Jyuni 500RPM Slipstream 120mm Fan - 3/4 Pin
Arctic Silver 5 Thermal Compound (3.5g)
I would also like the following, i cant be asked buying them of another company. I dont want to pay for delivery for such a small no of items.
2x Nexus Silicon Anti Vibration Fan Mount - x
1xNexus 120mm Silicon Absorber for 120x120mm Fans - x
Do overclockers Noise Absortion Material? any brand will do - x
Thanks very much
Before you get any replies, I'd take off those links to that competitor.. it says in the FAQ that if you post any links to competitors, you'll get your account suspended.
Edit: Ok. I can't advice on all of that although it does look pretty good. One thing I had noticed though is that although it will probably cope with it, that 450W PSU might be put under a lot of stress when you add any more bits to the rig. You might be safer getting a 520W one or even a 600W one.
What I'm saying is although that 450W one should cope, you'd be safer getting a more powerful one, just in case
All the base components are compatible but I didn't bother checking the case fans or that you have enough PCI slots/space near a PCI slot to install the sound card.
Excellent spec (note the Thermalright Ultra-120 Extreme CPU Cooler has been known to have an uneven base due to the manufacturing process and may require lapping)
i dont understand what you mean
Lapping "The process of ensuring a surface is flat, with the use of fine grade "wet & dry sandpaper and water, on a flat surface"
If the base is uneven then there will be insufficient contact with intel IHS, resulting in improper thermal dissipation of heat. Hence lapping if the base is uneven. You can check if the base is uneven by holding up to the light using a razor blade (see link 3).
1. http://forums.overclockers.co.uk/showthread.php?t=17813401&highlight=lapping+ultra+extreme
2. http://forums.overclockers.co.uk/showthread.php?t=17802533&highlight=lapping+ultra+extreme
3. http://www.cryo-laboratory.com/foru...89-thermalright-ultra-120-extreme-review.html
hi
thanks i am going to stick with the thermal ultra. Sorry but could some double check the system for me, i am concerned about the memory would it operate at 800mhz? i came across a site that says its PC2-5300 is this wrong?
i've got a Medusa 5.1 Surround headset, should i get the Auzentech X-Plosion DTS Connect 7.1 Sound Card - Retail or is it overkill? I don't have any fancy surround sound system, just the headset.
