Pc Tv MCE? Setup is this posible
Connecting a pc base unit to a tv monitor old style that has scart sockets
what do i require
We have motherboard, spare graphics card and old tv card any ideas. The tv had asl the 3 yellow white and red rca connection on the front! Was going to run media portable eidition or windows media centre on it / xp
Graphics Card
WinFast A400 TDH
NVIDIA GeForce GPU 6800
Form Factor1-Slot
Clock 325/700MHz
Memory DDR/128MB
Output DVI, VGA, TV-Out
Data Bandwidth 256-bit
Superscalar GPU architecture 12
Graphics Core 256-bit
Memory Bandwidth 22.4GB/sec
Fill Rate 6.4 billion texels/sec. 3.9 billion texels/sec.
Vertices per Second 406 Million
Memory Data Rate 700 MHz
Pixels per Clock (peak) 12
Textures per Pixel* 16
400MHz RAMDACs
0.13 Micron Process Technology
AGP 8X
CineFX 3.0 Engine
Unified Driver Architecture (UDA)
Intellisample 3.0 Technology HCT
High-Precision Graphics
nView Multi-display Technology
Digital Vibrance Control (DVC) 3.0
Architected for Cg
Microsoft® DirectX®9.0c Optimizations and Support
OpenGL®1.5 Optimizations and Support
High-performance, high-precision 3D rendering engine
On-board DVI support up to 1600x1200 resolution
Vivid NTSC/PAL TV-out support with flicker filter
*Maximum in a single rendering pass
Motherboard
Processor
- Designed for AMD Socket 939 Athlon64/ Athlon64 FX processors
- 2000MT/s system bus using Hyper Transport™ Technology
- Support AMD next generation Dual Core CPU
- Support AMD CPU Cool 'n' Quiet Technology
Chipset
- ULi M1689 single chip
Memory
- Four 184 -pin DIMM sockets
- Supports Dual DDR400 Un-buffered ECC/Non-ECC memory
- Supports maximum memory capacity up to 8GB
Graphic
- AGP 8X
SATA RAID
- Supports SATA 1.5Gbps data transfer rate
- SATA RAID 0/1
LAN
- On board 10/100MB LAN
Audio
- On board 5.1 channels Audio CODEC
- Supports auto jack sensing and optical S/PDIF Out
ABIT Engineered Technology
- ABIT SoftMenu™ Technology
- ABIT CPU ThermalGuard™ Technology
Internal I/O Connectors
- 1 x AGP 8X, 5 x PCI slot
- 1 x Floppy Port supports up to 2.88MB
- 2 x Ultra DMA 133/100/66/33 IDE Connectors
- 2 x SATA Connectors
- 2 x USB 2.0 headers; 1 x CD-IN header
Back Panel I/O
- 1 x PS/2 Keyboard, 1 x PS/2 Mouse
- 1 x Serial Port connector, 1 x Parallel Port connector, 1 x S/PDIF Out
Connector
- 1 x Audio connector (Line Out, Line-in, MIC-in)
- 4 x USB Connectors, 1 x RJ-45 LAN Connector
Dimension
- ATX form factor (305x 245mm)
TV Card
Leadtek WinFast TV2000 XP Deluxe
Hardware Interface 32-bit PCI 2.1 bus mastering
Compatibility Graphics drivers must include DirectX 8.1 software Video Standards
Video Standards NTSC, PAL or SECAM
TV Tuner NTSC, PAL I/DK, PAL BG/DK, PAL M/N, SECAM LL, SECAM BG for respective model
Full 181 channels supported
FM Tuner Stereo FM 76Mhz ~ 108Mhz (for Japan only)
88Mhz ~ 108Mhz (elsewhere except Japan)
Video Display True color overlay in scaleable video-in-a-window
Video Format RGB32/RGB24/RGB15/YUY2
Drivers WDM drivers for Windows 98SE/ME/2000/XP
Connectors 2 F-connectors for RF TV and FM signal inputs
1 phone jack for I/R sensor
1 Stereo phone jack for audio output
1 MiniDIN 6-pin connector with one S-Video and 1 RCA connector for Video input
1 Stereo phone jack for audio input
Bundle software WinFastDVD from Leadtek
Video Studio 8.0 from Ulead
Cool 3D 3.0 from Ulead
Package Contents WinFast TV2000 XP Deluxe card
Remote control & batteries
IR sensor plug
FM antenna cable(FM version only)
WinFast TV drivers/utilities CD-ROM
1 MiniDIN A/V cable
1 stereo audio cable
User's manual
Minimum System Requirements Live TV Intel® Pentium® 3, 600MHz
DVD recording Intel® Pentium® 4, 2.4 GHz or higher or equivalent AMD processor
One available PCI 2.1 compliant slot
MS Windows 98SE/ME/2000/XP
Graphics sub-system with DirectX 8.1 or above
16-bit sound card
what do i require
Graphics Card
WinFast A400 TDH
Form Factor1-Slot
Clock 325/700MHz
Memory DDR/128MB
400MHz RAMDACs
AGP 8X
CineFX 3.0 Engine
Architected for Cg
Motherboard
Processor
Chipset
Memory
Graphic
- AGP 8X
SATA RAID
- SATA RAID 0/1
LAN
Audio
Back Panel I/O
Connector
Dimension
TV Card
IR sensor plug
1 MiniDIN A/V cable
User's manual
16-bit sound card
