I am connecting my RX 7900xtx to my 4k 144hz TV and would like to know what cable do i need to connect with ?
I’m assuming it’s a S90C you have?
If so you’ll need a hdmi 2.1 cable. Make sure it’s certified.
Should be fine over HDMI with the right cable. Only Geforce users have problems with this![]()
That sounds like the tv HDMI is not picking up the graphics card signal due to a HDMI handshake delay. Could be caused by the PC going to sleep/hibernation or by tv settings. Have you tried tv game mode if it has it (newer tvs do) and is your tv firmware upto date? Also have you set up the pc settings for 4k in nvidia control panel under control panel "Display / "Set resolution" (you can google/Youtube guides how to do it)I find when I am connected to my TV via HDMI in 4K and I switch off my TV but leave the PC running, often when powering up the TV again, it will revert to 1080p. I have to reinstall the Nvidia drivers to fix it.
Do any TVs have DisplayPort yet?Even with an AMD GPU some TVs only support the lowest latency operation over DisplayPort, and/or PC/Gaming mode only works via a specific HDMI or DP connection and/or VRR only works on a specific port or port(s), etc. you need to know details of the display really to advise best.
Of course you can .Was going to ask a similar question, if a LG G3 OLED could be used for PC gaming? I was thinking of getting a new PC but thought of using my TV rather than a monitor.
Does anyone do this? How is it?
haha, depends on what you're talking about. TV yes.Of course you can .
As long as you sit far enough away to be comfortable then go for it.
Have you got a big one ?![]()
Not sure if thats aimed at me, I was meaning more about the picture quality etc, not the plugging a cable inMind boggles how people find it so complicated plugging a hdmi cable from their pc to their TV..
You should look into oled burn in if it's a expensive TV .haha, depends on what you're talking about. TV yes.
I have a 77in G3, I sit about 8ft away. I fancy getting a new PC, but dont know if I can be bothered going up to a spare room to use it
Not sure if thats aimed at me, I was meaning more about the picture quality etc, not the plugging a cable in![]()
