Pc tower Upgrade
3 Feb 2018
A bit over a year ago the good people from this forum help spec me my first complete gaming pc build. The case was the mesh Zalman i3 Edge MIDI-Tower as it was unavailable I got the same model with the solid front version this got so hot I took the plastic front panel off and snapped it and now the dust is a real problem with no front cover. I’d like some advice on choosing a new case I’ve been looking at the Corsair 4000d I’d like to spend £50 to roughly £90 thanks for any help.
I think the corsair 4000d airflow cases look good, and got decent reviews too.
Other ones I personally like the look of and think offer decent space and airflow:
https://www.overclockers.co.uk/cors...k-tempered-glass-cc-9011181-ww-ca-24z-cs.html
Corsair Carbide 275r
https://www.overclockers.co.uk/frac...ower-case-white-tempered-glass-ca-07l-fd.html
Fractal Design Meshify C
I have the fractal meshify c myself and happy with it. There is a second generation of this available now ('meshify 2 compact'), but it's more expensive.
https://www.overclockers.co.uk/be-q...ower-case-white-tempered-glass-ca-13x-bq.html
Be Quiet 500DX
Building in a 5000x..can say the corsair case is decent(x version was on offer) went for the 5000 series rathwr than 4000 only as i already had a 360mm aio which i wanted on the top rather than vertically on the front. I like that the mesh filters are all accessible from the outside, without having to open it up
4000 airflow readily available for £64 also, so if you go for that, dont pay any more
