Hi all,
I am having some problems with my PC.
It seems to turn itself off whenever it gets stressed (loading games, etc) and sometimes when I accidently knock into the computer, it turns off again. I just opened the PC and checked it's all connected properly and everything seemed OK. I also cleaned some of the dust out incase that was a problem.
I don't think It's overheating because the temps are fine and I have good enough cooling.
I just put the case back together and now nothing is displaying on the monitor...
Any idea's what could be causing this?
Specs:
P4 S478 3.2Ghz
Asus P4P800SE
Inno3D 256MB 6800GT
X-Pro 460W PSU
Windows XP Home
EDIT:
Right. I just re-opened the PC and reconnected the GFX card and it seems to be more stable now and the monitor is displaying. I just kicked the case and it didn't turn off this time
I still think there is a problem with the PC turning off when stressed - do you think this could be a driver issue?
I am tempted to try a complete re-install because I haven't reinstalled for over a year now...
GPU temperate is 53C.
Specs:
P4 S478 3.2Ghz
Asus P4P800SE
Inno3D 256MB 6800GT
X-Pro 460W PSU
Windows XP Home
EDIT:
