PC turns on then off then on and works fine
12 Sep 2007
I just overclocked a q6600 g0 to 3ghz with a 5:6 and left all voltages as normal.
When i push the power button the computer initially starts up but then turns itself off and after a few seconds it boots up as normal. Initial prime95 tests haven't shown a problem though I will need to run it overnight at some point.
Is this anything to worry about?
My brothers does this, press the power button it turns on, then turns off, then turns on and no problems :D
Nothing to worry about tbh ;)
I get this to only if i turn off my PC at the wall socket or back of PC after shut down....if i dont the PC starts up normally
My motherboard does this - I raised a query on here to be advised it's a good thing . :D
Some check carried out by the board.
Running an Asus P5K Premium.
