Hi,
Basically I just brought some new 1066Mhz ram so I can over clock to 4Ghz so I started off by increaseing the FSB by 10, worked and tested so decided to bump it up another 10 and then I loged onto PC and when OCCT was running it was saying my CPU was running at 2.8Ghz (434 x 6.5) when it should be 3.6Ghz (434 x 8.5). got no idea what is going wrong,
Here are some pics of my bios set up:
Links:
http://img831.imageshack.us/img831/7995/dsc01474xa.jpg
http://img710.imageshack.us/img710/2406/dsc01473j.jpg
Here is pic of Coretemp:
P.S also this was when running OCCT stress tester so I know its not the intel speed step thats underclocking to save voltages and heat
Voltages:
CPU: 1.27500
CPU PLL: 1.54
FSB term: 1.24
DRAM: 2.10
NB: 1.26
SB: 1.20
If anyone could help that would be nice
oh and rig is in the SIG but got new OCZ HCP reaper -pc8500 instead of the pc-6400
Links:
Voltages:
CPU: 1.27500
CPU PLL: 1.54
FSB term: 1.24
DRAM: 2.10
NB: 1.26
SB: 1.20
