PC under peforming...
10 Sep 2006
Manchester
Last few days my pc has been 'under-performing' for eg:
in counter strike source i normaly get around 200-300fps on a 40manpub server , now i only get around 30-50fps.
i'v reset the cmos so everything is stock and it just made things 10x worse...
i ran geekbench aswell and the score i got @ stock is = 262
i ran 3dmark06 and on the first graphics test im getting around 60-67fps and i normaly get 75-80 :/
Any reason why my pc is under performing?
*spec in sig*
ty in advance =]
Seems fine but you should run an up to date spyware program like Ad-Aware and also a virus scan. Did you notice this slowdown after installing new hardware/software or updating any drivers?
Glad you solved your problem CarlD, even if it took the hassle of re-install.
Tombo - What benefit does limiting FPS give?
