pc unstable 320fsb+ in dual channel mode
1 Aug 2006
Leeds
basically my ocz pc6400 2x512mb gold will not run my conroe e6300 at ANYTHING above 320ish 330ish stable, get errors........
HOWEVER.
if i pop em side by side in slots 1 and 2, sp2004 and the likes run all day????????????????
messed with voltage, set slackest timings, but no go.
mb is an asus p5b vanilla.
any thoughts?
possibly mb bios related? im runnin 309 latest one.
seems stable at <300 fsb.
doin a memtest from dos tonight...
okay, so i did a memtest86 in dos.......
all ok at stock
raise fsb to 300 and BOTH sticks generate errors, regardless of speed and voltage.
but, put both in at same time in single channel only and all is fine at same FSB????
anyone care to enlighten me???
PLEASE!
if the ram runs at slightly different rates (ie ones getting errors) then you'll get issues with dual chan as they won't give the same results, but singles ok as they errors may be overlooked.
try upping the voltage.
or just leave it....it seems to be working
the reason dual channel is advised is becasue it helps with the stabilty of the memory controller, if its stable in non dual channel mode, it really doesnt matter if you have it dual or not.
i think anyway, i could be tottally wrong! :(
