Hi guys,
What sort of upgrade would you say would be worth while on the below rig? I have a NAS, so storage is not an issue. I do play games on the PC, so I would think graphics card but I don't know.
Looking to spend around £150/£200, below is my current spec.
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz, oc'd to 2.65GHz (big heat sink on it)
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard
Corsair XMS2 2GB (4x1GB) DDR2 6400C4 TwinX Dual Channel
Western Digital VelociRaptor 150GB 10000RPM SATA-II 16MB Cache
Corsair HX 520W ATX Modular SLI Compliant Power Supply
Cheers!!!!
Cheers!!!!
