Hi,
I'm looking to purchase a custom build from Overclockers.
Can You please advise on hardware options.
Many thanks in advance for any help.
Purchase timeframe
1-4 weeks.
Exact Overall Budget
£4000
What exactly is the build for in terms of use?
Purchase timeframe
1-4 weeks.
£4000
- Gaming, (Fps, Rts & turn based). Resolutions/details etc are probably limited due to existing monitor, (please see peripherals below).
- Design work, (Sketch-up).
- Rendering (Vray). Resolutions/details etc are probably limited due to existing monitor, (please see peripherals below).
- Gaming hardware; I’m completely open to whatever is recommended.
- Design hardware; As I understand, Sketch-up can only utilise a single, (Cpu) core and is not multi-threaded. So high benchmarking single core Cpu performance.
- Rendering hardware; Vray does utilise multiple Gpu’s but two would be my limit!
- Display: two monitors.
- Win 11 pro 64-bit
- CPU: AMD Ryzen Threadripper 3970x 32-Core (3.69GHz)
- RAM: 64 GB DDR4 @ 1064MHz (15-15-15-36)
- GPU: 2x NVIDIA RTX 2080Ti 3071MB (Gigabyte)
- M/B: Asus Rog Strix TRX40-E Gaming
- Storage: 1863GB Seagate Sata SSD
- Monitor: LG 27gl850 (2560 x 1440 144Hz) & BenQ XL 2420Z
- Power supply: 1200w, (I think)?
- At a Later date I would update my monitors but this would be in a separate budget.
- I have been contemplating using my existing Pc as a rendering node for Vray, something I have no experience in... But with this in mind none of the above would be used in the new build.
- WiFi: not required.
