Hi all,
A while ago I built a gaming PC on recommendations from friends and my own research. I was also on a limited budget. I'm now looking to upgrade this so I can run games on the highest settings and still achieve a great FPS. I've done a bit of research and found I'll probably have to swap out or add some more RAM/Graphics cards/SSD and also get a much better monitor. I've listed the specs of the whole PC just in case it will help. I really looking for where my build is most lacking, what I should add to/swap and any recommendations for parts in particular.
Thanks everyone
- Graphics Card: Asus DUAL-GTX1060-O3G NVIDIA GeForce OC Edition 3 GB GDDR5 192 Bit Memory PCI Express 3 Graphics Card 24 X 4 X 11.5 cm - Black
- Motherboard: Asus Prime B350-PLUS AMD DDR4 S-ATA 600 ATX Motherboard - Black
- CPU: AMD Ryzen 5 1400 Desktop CPU - AM4/Quad Core/3.2GHz – 3.4GHz Turbo/8MB/65W
- RAM: Ballistix Sport LT BLS8G4D240FSE 8 GB (DDR4, 2400 MHz, PC4-19200, CL16, Dual Rank x8, DIMM, 288-Pin) Memory - Red
- SSD: Samsung 250GB 850 EVO M.2 SATA Solid State Drive
- HDD: Seagate ST1000DM010 1 TB 3.5 Inch Barracuda Serial Hard Drive
- PSU: EVGA 600 B1, 80+ BRONZE 600W, Includes FREE Power On Self Tester, Power Supply 100-B1-0600-K3, Black
- Monitor: ASUS VS229NA Widescreen VA LED Monitor 21.5 Inch (1920x1080, 5 ms, VGA, DVI-D, 3000:1) - Black
- Case: CiT G Force Gaming Case with 15 LED Blue Front Fan - Black
Thanks everyone
