Hi
I am wanting to upgrade my pc and am in need of some expert advice please. My current spec is:
amd athlon XP barton 2800+
abit nfs-7s v2 mobo
512mb twinmos
wd 120gb hard drive 8mb cache
sapphire radeon 9600 pro 128mb
enermax EG465AX-VE(G) 460 watt ver 1.2 atx 12v
coolermaster aero 7 heatsink
as you can see, it's a dinosaur!! I'm thinking of upgrading to this spec:
intel core2duo E6600
asus pb-e mobo
wd 160gb hard drive 16mb cache
oc 7300gt 256mb graphics card (not a gamer!!!)
2gb GeIl pc6400 (800mhz) memory
I need some advice on new upgrade though:
1. I understand that i now need a new psu for this upgrade (atx 2.0 spec).Which psu can you recommend? what wattage do I need to run this new upgrade very comfortably?
2. Can I use the heatsink that comes with the retail intel core2duo cpu or do I need something better? Can I still use the coolermaster aero 7?
3. Will the p5b-e mobo fit into my existing coolermaster wavemaster case?
4. will i still be able to connect my existing nec cdrw IDE drive to the p5b-e mobo?
5. will i need more fans, therefore will I need to buy a new case? the case has currently got 2 x 80mm fans at front behing hard drive & 1x 80mm fan at the rear.
6. Does the p5b-e mobo have the capabilities to enable me to set up a wireless home network between my pc & laptop? (obviously I'll be using a wireless router)
If you can answer all questions for me I'd really appreciate the help.
Thanks
abit nfs-7s v2 mobo
512mb twinmos
asus pb-e mobo
Thanks
