PC Upgrade advice
6 Sep 2016
My existing system is.
Intel Xeon 5670
24GB triple channel
Full tower case
ATI 480
Coolermaster Stacker 810
500GB 2.5" SSD
PCI -E NVME adaptor with 1TB NVME
Noctua heatsink - able to get adaptor this HSF onto new CPU? Unsure of model, It's a large very tower with dual fan
USB 2 front hub
Unsure of PSU, possibly 800W Bequiet or Seasonic
27" 1440p freesync VA monitor, with a couple of faulty LED, will decide if annoying enough to replace monitor
If or when I upgrade will a motherboard, memory & CPU bundle fit ok
I wouldn't mind replacing the USB hub on front with modern 5.25" bay with USB3, USB-2 etc.
Are GPU's still ridiculously expensive or have they dropped down to sensible price?
For best value for gaming, AMD or Intel CPU this gen?
And for GPU, AMD or Nvidia?
I've just added two CPU/mobo combo of both types, and 32GB memory, just random things to see pricing, obviously not going to order two CPU and two mobo.
What budget do you have, and what use case do you have?
The noctua cooler be fine, just buy a fitting kit from them.
Do you want to stick to intel or look to AMD.as an alternative?
GPU wise pricing can be expensive depending what your after
It depends, but with the GPUs you have quoted in your image the 3050 is generally regarded as poor value against the superior RX 6600.
The 4060 8GB has dropped to £250ish and that does pretty well against the RX 7600 8GB.
None of those CPUs are what I'd buy for 1440p gaming though, since their lifetime would be very limited at this resolution and rely on upscaling for the latest games.
For 1440p I'd want at least a 6750 XT (they're available around £300), but preferably a 4070 non-Super or 7800 XT (~£450).
Yeah, there's nothing special about newer stuff if you have an ATX compatible case.
They are WAY better than during the Crypto mining boom, but hard to call them great value. You can get a big upgrade to a RX 480 for not loads, since something like the 6750 XT is way faster than what you have.
It depends, but since the general advice is to avoid 13th-14th gen until confirmed otherwise, you're realistically limited to 12th gen or AM5 for a new build (unless the budget is very tight, in which case a 5600/5600X or 12400F build is fine).
What else do you do with the PC?
If you only game, the 7600 is hard to beat and worth it for the longer-term upgrade potential, but the 12600KF and 12700KF are available at decent prices if you HAVE to have Intel.
The productivity performance on the 12700KF is superior to the 7600.
Likely, but you will need the exact model to confirm that.
"For best value for gaming, AMD or Intel CPU this gen?"
The 5700X3D Cannot be beaten for value VS gaming performance.
If you want latest gen AM5, the 7800X3D is a gaming monster and a fair price.
Something like that?
I normally like gigabyte boards, but read they've not been great?
Gigabyte Gaming X AX is available for £150 and features seem fine for that price, but OCUK have delisted it.
Eagle is another alternative and that is a bit cheaper, but LAN is only 1Gb and most of the rear USB ports are USB 2.0.
AMD Ryzen 7 7800X3D and
yes
RTX 4060Ti xxx 16GB
Very unlikely, they are usually priced too high for the performance they offer. One of the problems is that they didn't increase the bus width with the memory, it is literally just doubled. In some cases a 4070 non-Super is cheaper and they're significantly faster.
Speccing up a system for someone also, here are two systems, one AMD, other Intel- I have added AMD and Nvidia to each build for him to decide which one. Memory is ok for each? What about monitor (gsync/freesync compatibility) tried to keep similar price for cpu/gpu as possible.
how do you minimise those images lol they're too big
Asrock B650 LIVEMIXER (Socket AM5) DDR5 ATX Motherboard
SKU MB-18W-AK
£234.95£159.98
fiber_manual_recordPre order
Crucial Pro 48GB (2x24GB) DDR5 PC5-48000C48 6000MHz Dual Channel Kit
SKU MEM-CRU-01087
£199.99£139.99
fiber_manual_recordIn stock
AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor - Retail
SKU CP-3DT-AM
£419.99£359.99
AMD Ryzen - Space Marine & Unknown 9 Awakening Games Bundle
free
SKU DIG-AMD-02908
Quantity: 1
£100.00£0.00
be quiet! Pure Rock 2 CPU Cooler - 120mm
SKU HS-01J-BQ
£34.99
be quiet! Pure Power 12 M 850W ATX 3.0 80 Plus Gold Power Supply
SKU CA-14R-BQ
£139.00
Samsung 990 Evo 2TB M.2 2280 PCI-e 4.0 / 5.0 Hybrid NVMe Solid State Drive
SKU STO-SAM-01533
£189.95£179.99
WD Gold 10TB 3.5 7200RPM HDD 256MB Cache Datacenter Hard Drive (WD102KRYZ)
WD Gold 10TB 3.5" 7200RPM HDD 256MB Cache Datacenter Hard Drive (WD102KRYZ)
SKU HD-56G-WD
£249.95
Fractal Design North XL Full Tower Charcoal Black Case
SKU CAS-FTL-02372
£169.99
OcUK Mega Mat Medium Elite Tactical Gaming Surface
SKU GS-001-OP
£9.95
Logitech G502 HERO High Performance Gaming Mouse (910-005471)
SKU KB-25U-LG
£64.99
MSI 27 MAG 275CQRF QD 2560x1440 VA 170Hz 1ms A-Sync HDR Widescreen Gaming Monitor
MSI 27" MAG 275CQRF QD 2560x1440 VA 170Hz 1ms A-Sync HDR Widescreen Gaming Monitor
SKU MON-MSI-00581
£348.95
Ducky One 3 Classic Fullsize USB RGB Mechanical Gaming Keyboard Cherry Brown - Black UK Layout
SKU KB-2A7-DK
£159.95£129.95
Asus TUF AMD Radeon RX 7800 XT 16GB GDDR6 PCI-Express Graphics Card
SKU GRA-ASU-01327
£599.99£499.99
AMD Radeon - Space Marine & Unknown 9 Awakening Games Bundle
free
SKU DIG-AMD-02939
Quantity: 1
£100.00£0.00
MSI RTX 4070 SUPER VENTUS 3X OC 12GB GDDR6X PCI-Express Graphics Card
SKU GRA-MSI-03253
£589.99£569.99
Edifier Studio R1600T III 2.0 60W Speakers (Maple)
SKU SP-040-ER
£84.95
Asrock Z790 PG Sonic (LGA 1700) DDR5 ATX Motherboard
SKU MB-194-AK
1 2 3 4 5 6 7 8 9 10 11
£245.99
clear
Intel Core i7-13700KF (Raptor Lake) Socket LGA1700 Processor - Retail
SKU CP-6B7-IN
£389.99 £299.99
clear
SKU MEM-CRU-01087
£199.99 £139.99
clear
Arctic Freezer 36 120m Black CPU Cooler - 2x 120mm
SKU COO-ARC-02420
£22.99
clear
SKU CA-14R-BQ
£139.00
clear
SKU STO-SAM-01533
£189.95 £179.99
clear
SKU HD-56G-WD
£249.95
clear
SKU CAS-FTL-02372
£169.99
clear
SKU GS-001-OP
£9.95
clear
SKU KB-25U-LG
£64.99
clear
SKU MON-MSI-00581
1 2 3 4 5 6 7 8 9
£348.95
clear
SKU KB-2A7-DK
£159.95 £129.95
clear
SKU GRA-ASU-01327
£599.99 £499.99
clear
free
SKU DIG-AMD-02939
Quantity: 1
£100.00 £0.00
MSI RTX 4070 SUPER VENTUS 3X OC 12GB GDDR6X PCI-Express Graphics CardTop
SKU GRA-MSI-03253
£589.99 £569.99
clear
