Hi guys,
This may be quite a long one but I will try not to waffle too much. Before anything here are my current system specs.
Things I want to upgrade:
CPU: I am looking to upgrade my processor, first and foremost. I am a heavy gamer but most of my gaming comes in the form of simulation / grand strategy games. Games like Total War, Paradox games such as Stellaris and Cities Skylines, both of which require a lot of processing power. Recent performance tests show me that my CPU is really starting to bottleneck me in games which require a lot of processing power.
A common problem which comes up in the games I play is that they apparently do not work well with many cores on a CPU (I know nothing about how any of this works so I may be talking rubbish here), so I was thinking maybe a CPU with less cores but more power would be better? I don't know.
Motherboard?: I then realised that I have had both my motherboard and CPU for at least 4 years, so maybe it is also worth me upgrading my motherboard while I am here? I don't really know how good/bad my current motherboard is if I am being honest. I would want a motherboard that supports 5.1 surround sound and 4 sticks of DDR3 4GB RAM.
Monitor: I am also looking at buying a new 32 inch monitor for my PC. As you can see I currently use a (rather old) TV as my desktop monitor. I will probably keep using this as a second screen for basic things while gaming on my new screen.
Case?: If I am going to get a new motherboard I will also want a new case as my current case is old and battered.
Things I don't want to upgrade:
RAM: I think I have enough
OS: Happy with 10 Pro
Storage: My SSD/HDD combo works fine and is new
GPU: Average I know, but I don't play many high end graphics games and I am happy to play them on low settings if I do.
Power Source: Recently purchased a PS with a lot of spare capacity remaining.
Budget:
I think between £6-800 is my maximum for the parts I want. I would like to get some fairly high end kit so that I don't have to upgrade them for a good number of years. Also as I said, my CPU is the main component of how I game so I don't want to go in cheap and continue to struggle as I am currently doing!
Please let me know if any other information is required!
Thanks for any future help!
Operating System
Windows 10 Pro 64-bit
CPU
AMD FX-6100 Six-Core Processor
Zambezi 32nm Technology
RAM
16.0GB Dual-Channel DDR3 (9-9-9-24)
Motherboard
ASRock 970 Extreme3 (CPUSocket)
Graphics
32W_LCD_TV (1920x1080@30Hz)
2047MB NVIDIA GeForce GTX 760 (ASUStek Computer Inc)
Storage
232GB Samsung SSD 850 EVO 250GB (SSD)
931GB Western Digital WDC WD10EZEX-00BN5A0 (SATA)
CPU
RAM
Motherboard
Graphics
Storage
Budget:
Much appreciated. I look forward to the shopping list if you check back
