Since I last posted in this section I have replaced my broken hard drive with another and added 2GB of ram as recommended by someone on here and since then the PC has been operating slightly better and faster which is good news.
I want to upgrade more parts / the performance of the PC. The parts i've considered are the fans and the cpu cooler but I am not sure which will be the best to consider which is where I need your help.
I've taken some photos (sorry for the rather poor quality)
With this pic I am not sure what size cooler I could have because of the plastic type air flow thingy that is quite close probably 2-3cm between two.
The specs of my PC are:
3gb ram
2 x sata hard drive
ati radeon 300 series
intel p4 3.2ghz
motherboard is Asus P5 LD2 SE
The CPU cooler looks like it is a 4 pin speeze.
I'd just like to know of any recommendations to improve air flow in the case since my cpu was touching 99c but then I managed to get it down to the 40-50c mark.
Thanks
3gb ram
2 x sata hard drive
intel p4 3.2ghz
Thanks
