Thanks to some suggestions by Tetras, so far I've bought:
Boot drive - WD_BLACK 1TB SN770 M.2 2280 PCIe Gen4 NVMe
RAM - Corsair VENGEANCE DDR5 32GB (2x16GB) DDR5 5600 (PC5-44800) C36 1.25V
PSU - Corsair RM850 850 Watt 80 Plus Gold Fully Modular ATX Power Supply
Still welcoming suggestions for the following items:
(remember, the CPU will be either a i5-13600K or a i7-13700K)
Motherboard - Tetras suggested 3 mobos but the one that stuck out was the
ASRock Z790 Riptide as it has 8 SATA connectors & and a PCIe-1 slot, which will take care of my
current components without the need for any additional PCI cards. I think the
ASRock Z790 Riptide is a good choice, so can anyone make a case for another mobo??
CPU cooler - Tetras suggested the
Scythe FUMA 2 cooler but also asked whether or not it would fit. The answer to this is, I don't really know!
Here's my current Raijintek Themis CPU Cooler sitting on top of my i5-4670
(excuse the mess of cables, I'll be tidying this up big time...
The Raijintek Themis is (WxDxH) 127×75×155 mm. I think the
Scythe FUMA 2 might fit, as long as it doesn't foul the GPU if it is placed in the PCIe slot immediately below? Some pics
online of this cooler seem to show no GPU card immediately below it.
I'm a bit confused by all this and whether or not my GPU would fit on the top PCIe slot on the ASRockZ790 mobo??
Also, I need an air cooler, end of. With my current i5-4670 CPU and 6 case fans, the CPU sits around 22-27°C idle.
Any advice greatly appreciated!
