PC Upgrade
29 Apr 2011
i have purchased amd phenom 2 x4 quad core bundle and a 550w PSU , i will use my own HDD (160gb 7200rpm) is the 550w PSU going to be enough? and is there anything else i will need to buy for example video/sound or network cards? thx!
the board should have built in sound and network. but you will most likely need a graphics card. and that psu should be fine. but what brand is the psu?
a case to put it all in :p lol
if you wanna play games get a graphics card as mentioned above.
I'd recommend the 5850 at the price it's at TODAY ONLY :eek:
its still in the warehouse of the ocUK so i guess i can just cancell it, what would be best and cheapest option for me to run this system?
Your basket
Product Name Qty Price Line Total
Xenon AMD Phenom II X4 840 3.20GHz Bundle - Quad Core Xenon AMD Phenom II X4 840 3.20GHz Bundle - Quad Core £156.00
(£130.00) £156.00
(£130.00)
Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £107.99
(£89.99) £107.99
(£89.99)
BeQuiet Pure Power L7 530W Power Supply BeQuiet Pure Power L7 530W Power Supply £42.98
(£35.82) £42.98
(£35.82)
is this setup any good for games at the moment?
Your basket
(£130.00) £156.00
(£130.00)
(£89.99) £107.99
(£89.99)
(£35.82) £42.98
(£35.82)
Why do you ask the questions after you've bought stuff?
That setup will be fine for gaming.
The graphics card is as good as current ones in the £130-£140 price range:
http://www.anandtech.com/bench/Product/295?vs=291
http://www.anandtech.com/bench/Product/295?vs=313
