Does any one know where I can get a transparent side panel for the Lian-Li PC-V2010? They show one on there site under part number W-V2010 A (Black) but finding a supplier is a different story!!
Sorry no luck I tried all the suppliers I know of and use and nothing, the only thing I could think of if asking the Lian Li community on their website. Maybe they can shed some light on where to by these in the UK because all I found was all in the US and Canada and your shipping costs would be very expensive.
Explain to them you need transparent Side Panel I'm sure somebody will now where to get one. Although I could not find anybody in the UK at all. I would asume you need a black one.
W-V2010 Transoparent Side Panel
OMG is it just me or does this look like a computer mounted to a skateboard...?
I have the same case and had given up looking for one of these windows. I was considering cutting it myself but i don't trust myself with power tools and a £200 odd case. The Lian Li one will probably be much better quality as well.
That's some good info there chasb441 but i would recommend you remove the competitor references as that is against the forum rules. We wouldn't want a mod coming along now and playing with his ban hammer?
I plan on purchasing this case for a new build in the coming months, and was also looking around for one of the windows but had no luck. If OcUK were to get some in stock that would be awesome! (As I notice they do stock another Lian-Li window, just not the one for this case. )
had an update from another site. they will have them in soon. not able to pre-order though!!!! ....dooooh!.so when i have mine on order anyone else who needs one just yell on here and i will send you the info
£50? Cost if you look elsewhere is £19.56 for the cut then what £5.99 for plexi from same place. Just have to pay for postage both ways which will be what £5-10 max.
