- 20 Feb 2009
- Ashton-Under-Lyne
I've just taken my PC apart to replace the watercooling coolant & pipes, cleaning out the blocks whilst I was at it. Obviously this means almost completely dismantling the PC (something I've done on numerous occasions previously, so had no concerns about).
Unfortunately once I had reassembled everything & hit the power button to turn it on, nothing happened...
When I say nothing happened, I mean nothing, the fans didn't even move.
I've got an LED on my motherboard which lights when there's power (even is standby), which continues to be lit.
I've tried disconnecting the PSU Mobo connector & manually turning the PSU on, and it turns on & spins the fans & my pump correctly.
I've tried bridging the 2 mobo PWR SW pins manually, nothing happens.
Does anyone have any ideas as to what might be the issue, or any ideas for troubleshooting?
Specs:
Mobo: Asus P8P67 Pro
CPU: Intel 2500k
PSU: Corsair HX750W
GPU: 2x ATI 7970s
RAM: 4x 4GB Crucial Ballistix
Specs:
CPU: Intel 2500k
PSU: Corsair HX750W
GPU: 2x ATI 7970s
