- 23 Jul 2021
- England
Hi all,
For over a month now, I've been without my Desktop PC.
The PC one day failed to power on - not even reaching POST.
Core Hardware:
As most the components were only a few months old, I initially did an RMA on the motherboard. Point of purchase ran a full stress test on it and found everything was in order and returned it back to me.
I then RMA'd the CPU which has been replaced with a brand new one.
Now all of my parts are back with me, I'm now still running into the same issue.
Running a breadboard test (necessary components on a wooden surface) results in the same issue, thereby making it unlikely that the case is the issue.
As the RAM is totally brand new, and I've tried multiple other sticks of RAM, I'm pretty sure this isn't the issue.
The CPU has been fully replaced, therefore this is unlikely the issue.
The PSU is brand new and includes a self test button that confirms it is functional.
My GPU I have swapped out for an older GPU I own (GTX 980).
With all of the above in mind, what on earth could be the issue? It's driving me up the wall.
The motherboard is clearly receiving power as the on-board power button is lit up, and the overclock dial (set to zero) is lighting up too.
When I power on the PC (via onboard mobo button) nothing happens. No system fans start up, no digital numbers appear on the mobo digital display. Nothing
Any and all advice is super appreciated, I've spent so many hours attempting to resolve this issue and I'm getting nowhere.
Thanks
Core Hardware:
- MSI Meg X570 Ace motherboard
- AMD Ryzen 4 5950X
- Nvidia RTX 2080
- 2 x 32 GB RAM (Corsair)
- CPU cooler (Corsair)
Thanks
