- 20 Apr 2015
I have just changed my PSU. When I tried to boot for the first time, the power light came on for a second and then went off again.
I unplugged everything and started again and discovered that as soon as any SATA device is plugged into the PSU and connected to the motherboard, the PC will not power on at all.
I have tried:
Using all four SATA ports on my motherboard
Using different SATA cables
Using different SATA devices (2 SSDs and a Blu-ray drive)
It is worth noting that the PC will power up fine if just the SATA cable OR the PSU connection is made, it just won't work with both connected at the same time!
All I can think is that the old PSU took the SATA connections on my motherboard down with it. Is that likely or is there anything else to try?
I have tried:
