OK, I have a PC with 2 nvidia graphics cards in 2 pci-e x16 slots. One is connected to the monitor and the other is connected to a 1080p hdtv over hdmi.
This all works fine and I have the desktop on both screen in extend mode.
Now what I am doing is running mediaportal, boxee or xmbc etc in full screen on the HDTV using a bluetooth remote.
The bluetooth remote basically just sends keyboard keys to control the media program using eventghost or something like that.
This works fine now the problem...... (I don't even think there is a solution)
For the bluetooth remote to funtion in mediaportal, boxee, xmbc etc the media program has to be the current active window.
So if someone is using the pc on the monitor to browse the internet or type a word document , the remote no longer works.
Now you can set it up so the remote sets the media program to the current active window and sends the command everytime you press a button on the remote, however this means if someone is typing in microsoft word and someone uses the remote to interact with the media program on the hdtv, the typing stops as it is no longer the current active window and the user has to select microsoft word again to begin typing.
So is there anyway around this or a solution to minimise it as much as possible without using another computer
