My pc
Seasonic 650 watt psu
i7 4770k 3.5 ghz
8 gb ram 2666mhz
Ssd evo 840 and intel plus 2 tb hdd
Asus maximus IV impact itx motherboard
R9 280 3gb graphics card.
I have a few issues pc does not keep time and i have replaced the batttery, it kept time for a few weeks then went back to how it was losing time, i have replaced it twice.
Pc does not always shut down, i shut pc down amd it restarts itself probably 70% of the time.
I cant run any games for more than 5 mins before the computer crashes,
I ran some tests on cpu and it kept failing after a few mins,
I have installed windows on another hard drive.to see if its software issue but i had same problems
The pc is nearly 5years old and have over 5k hours in one game not sure if that has a bearing on amything but what do you think could be wrong with PC? Or is it time for a new one? Id rather fix this one tbh
i7 4770k 3.5 ghz
8 gb ram 2666mhz
