As pre-applied thermal compound is never fantastic, today I decided it was time to remove it and put some MX-4 on it myself.
This went completely to plan, I did it all by the book and everything went fine. this was until I tried to boot afterwards.
Cast your eyes over this: http://i.neoseeker.com/neo_image/170048/article/asus_maximus_formula/qled.jpg
This is part of my (well, not mine) Maximus III Formula mobo. When the pc starts up, the LEDs should light up when they are being used or being checked or... something along those lines. When I try, the CPU led flashes and then the DRAM led stays on for a few seconds, then the cpu led flashes again just as the pc turns itself off. Then it turns itself on again and cycles like this.
Half an hour later, the DRAM led doesn't light up at all.
I have no idea what could have gone wrong, any help is appreciated !
Thanks all, Fledge.
Thanks all, Fledge.
