Hi guys,
Grrrr. Got my new 8800GT today. Installed it, booted up fine. Brill! After a few hours of flawlessness I noticed my CPU fan was running at full speed, which it wasn't before, so I shut down and went into the BIOS to check the settings. Sure enough, CPU Fan speed control was disabled. Turned it on, along with System Fan control as well for good measure, and saved settings.
Oh dear. If only I had known it would bring a world of pain..
Machine refused to POST. Got as far as code 52, checking of memory. I've got 4x1Gb sticks of OCZ Platinum in it, so I took two out. POST'ed fine, got into BIOS, etc. How bizarre.
Put the two sticks back in. No POST. Used 3 sticks. No POST. Using the original 2 sticks, POST.
Ok, well 4Gb is overkill anyway, so I left the two other sticks on the side and decided to go back to using 2Gb for now.
Machine POST's, put in all my settings as per normal, save and exit, goes to load windows...
Bam. BSOD. CONFIG_INFO_ERROR or suchlike. Reset - same again, although this time just a generic STOP error.
Utterly confused. It was all working fine!
Help!?
IP35 Pro
E4300 (Now not overclocked for troubleshooting purposes
2Gb OCZ Platinum
BFG 8800GT
Help!?
IP35 Pro
2Gb OCZ Platinum
BFG 8800GT
