- 12 Sep 2005
- Norwich, England
Hi people,
Just after a sanity check...
System is a
Asus p8z77-v
I5 3570k
16gb corsair vengeance ddr3
Amd 7850 / amd 5450
Samsung ssd and a hd
Pc fails to boot to windows 10 1909 consistently, normally after windows logo and a few circle spins i just get a black screen which keeps monitor active. And only way to really get it running is if start up recovery has automatically ran, which restores to a previous point.
When actually inside windows running off the 7850 it will then normally lock up, cursor still moves for a bit but can't get to task mgr etc then screen will go blank and system has to be restarted.
Tried two screens and two graphics cards, both pcie slots
If I use the test 5450 I get the windows logo and then it freezes after a few circle spins, logos remain static on screen.
Pc always displays bios fine and any USB bootable media and it was fine when I reinstalled win 10 on the ssd.
Annoyingly nothing useful gets logged in event viewer, no graphics driver faults etc. Memtest ran fine, no errors. I've reseated all ram, all power cables, sata cables.
If I just run onboard graphics the system runs fine, boots fine every time.
I'm thinking it must be the motherboard/pcie, thoughts?
Thanks
System is a
Asus p8z77-v
I5 3570k
Amd 7850 / amd 5450
Thanks
