2 Mar 2007 at 15:59 #1 SuperJ SuperJ Associate Joined 23 Nov 2006 Posts 90 I have just bought a GIGA DS3 and a 8800 GTS to upgrade my system CPU = 6300 I built it all up and pressed power and all that happened was the sys fan jumped a bit, and that was it. It won't even make it to POST Any ideas?
2 Mar 2007 at 16:33 #2 melbourne720 melbourne720 Associate Joined 26 Sep 2006 Posts 1,945 Location West Bridgford Check the CPU is seated properly, reset the CMOS, check all PSU connectors and that nothing is shorting the board. What PSU is it?
2 Mar 2007 at 16:46 #3 SuperJ SuperJ Associate OP Joined 23 Nov 2006 Posts 90 It is a Hiper HPU 3s425 The RAM is PC2 3200 I have re-seated everything and it is still same. I try it will old MB and it is fine J
2 Mar 2007 at 16:48 #4 melbourne720 melbourne720 Associate Joined 26 Sep 2006 Posts 1,945 Location West Bridgford Your putting DDR RAM into a DS3?? That won't work surely...
2 Mar 2007 at 16:50 #5 killer_uk killer_uk Soldato Joined 12 Mar 2003 Posts 4,068 Location OcUK HQ melbourne720 said: Your putting DDR RAM into a DS3?? That won't work surely... Click to expand... Nah, it's PC2-3200, after a quick google search they do make DDR2 ram at 3200. Did you say you have reset the BIOS then?
2 Mar 2007 at 17:05 #6 melbourne720 melbourne720 Associate Joined 26 Sep 2006 Posts 1,945 Location West Bridgford killer_uk said: Nah, it's PC2-3200, after a quick google search they do make DDR2 ram at 3200. Click to expand... Weird. I think it is the RAM though.
2 Mar 2007 at 17:35 #7 SuperJ SuperJ Associate OP Joined 23 Nov 2006 Posts 90 No I haven't reset the bios, I will try that now It is definately DDR2 Should that work in a Ds3? I put my Elite P4M800Pro-M back in an it works fine with that RAM.
2 Mar 2007 at 19:00 #8 killer_uk killer_uk Soldato Joined 12 Mar 2003 Posts 4,068 Location OcUK HQ Sorry, I seem to have misread your post. I thought you were using the DS3 with the memory and were just trying to put a graphics card in. I'm prity sure that the PC3200 memory you are using isn't fast enough to run a 6300 conroe. The minimum you need is PC2-4200. I'm confused, I would wait till someone else gives you some advice, at least I've bumped the post to the top of the pile again.
