Hi,
Today my pc wouldn't turn on, well, the lights etc turn on, the power supply fan & graphics card etc are spinning (fans). However the keyboard and any other usb devices don't light up. The computer doesn't turn off after so long, it just stays on forever. Nothing displays on the monitor, not even boot / post screen.
I've resat the cmos battery and checked / replugged all connections. My instant gut feeling is that it is something to do with the fact that I was gaming when it happened and a blue screen came on (BSOD) and then it turned off, i smelt a slight burning so i quickly rushed to turn the power off & check if I could see anything.. Which I couldn't. I have checked the cpu for bent pins which I could not find any and I have checked the motherboard for blown capacitors. The motherboard does however still light up with the OC genie functions, so my gut instinct is the cpu, but I may be wrong which is why I am asking for some help. I have tried different ram and in different slots but this has not worked either. Basically it turns on, all the lights etc. but no power from usb's and no display / output from graphics card. HELP!? The processor was overclocked to 4Ghz / 1.36Vcore, But I have never had any issues with it before.
and then get a PSU tester and test
