- 20 Mar 2015
My pc has worked since building it (at least 12 months) with only two minor problems before
problem one
twice it has failed to start before but i waited 15-20 mins and it started like normal and the problem didnt return for a few months
problem two
every few weeks something in my pc sounds like it is hitting a fan blade
if i open the pc and look around there is nothing close to any blade
and if i reboot the noise dissappears and at all times the blades appear to spin normal
My current pc is
GeIL EVO Leggera 8GB DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC)
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW)
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC)
Be Quiet! Shadow Rock Pro SR1 CPU Cooler
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card
last night i was using this pc and everything appeared normal and this morning the pc it failed to boot up
i noticed it was rebooting constantly
i waited 20 mins like i did before and the problem was still here
i then tried it every 20-30 mins over the next two hours but the problem appeared to be more major than before
i opened the pc and did the following
1/ removed keyboard mouse and anything else attached to the pc retry booting
2/removed hdd ssd and cd rom retry booting
3/removed usb case speaker wires and anything else attached to motherboard retry booting(except for power switch and reset swich )
4/ removed sound card retry booting
5/ removed ram tried each stick seperatly retry booting
6/removed graphics card
it booted(or appeared to do so as it didnt reboot) and was stable
i was in luck i had my old graphics card as the msi r9 290 was only purchased at xmas
i put my old 5850 back into my pc and the booting error came back
i took battery out of comos waited 5 mins reput battery back in
tried a graphics card and it just kept rebooting
the pc motherboard has onboard graphics but when i tried to use them i couldnt get any output to the monitor
it appears the pc becomes stable with no graphics card but constant reboots when I install a graphics card (ive now tried two graphics cards )
atm i have hsf cpu motherboard,power supply and it appears to boot up
anyone with any idea how to fix it or what the problem is
problem one
problem two
My current pc is
