Hi all,
I've had my current setup for a long time:
I only really turn it on once every other week though now that I have a child, it's been working absolutely fine. However, I turned it on the other day and nothing came on the monitor and I noticed my wireless peripherals weren't connecting (meaning it wasn't getting to Windows). I can't see BIOS or anything, the monitor doesn't detect a connection. The fans and case lighting etc get going though when I do turn it on, so it's not completely dead. I also noticed the fans stay quite high speed (then lower after BIOS usually).
So far I've tried ...
Any advice would be appreciated. Thank you.
- MSI B450M Mortar AM4 mATX motherboard
- Ryzen 2600X CPU
- RTX 2060 GPU
- 16gb DDR43200 Corsair Vengeance RAM
- Corsair 700W PSU
- Trying a HDMI cable instead of the DP cable to the GPU (the monitor works fine, it works happily via HDMI to my work laptop)
- Tried removing the GPU and plugging the HDMI into the motherboard's HDMI socket (though this may not work as my CPU isn't a compatible CPU?)
