pc wont boot up
17 Apr 2007
stat city
my pc i bought from here a few months ago wont boot up. it has been working fine up untill today. what should i do?
check my past threads to see the system i bought. any help would be great.
- Intel Core 2 DUO E6600 2.40GHz Dual Core CPU Overclocked too a minimum of 2.93GHz and beyond. (9 x 333MHz - 1333MHz FSB)
- Arctic Cooling Freezer 7 Pro Intel approved cooler
- Arctic Silver 5 Heatsink compound professionally hand installed by our technicians
- Abit IP35 Intel P35 (Socket LGA775) PCI-Express DDR2 Motherboard
- Award winning Corsair 6400C4 2GB PC2-6400 CAS4 (2x1GB) Dual Channel Kit (Overclocked at 900MHz+)
- 500GB Western Digital Enterprise 16MB Cache SATA-2 Hard Drive
- NVIDIA 8800 GTS 640MB GDDR3 HDTV/Dual DVI (PCI-Express) DirectX 10 Graphics Card
- NEC 7173 18x DVD±RW Dual Layer LabelFlash ReWriter (Black)
- Black Sony Floppy Drive
- Antec NINE HUNDRED Gamers ATX Case
- OCZ 600W Next Generation Power Supply
i think it might be the gfxs card. i disconnected it and then turn the pc on and there was a loud bleep. does this mean anything ?
card is a 8800gts.
it just says check signal cable on the moniters. moniters work on other pc.
the pc that wont boot wont reset by pressing the reset button. i have to hold the power button for it to turn off. could it be the mobo?
Can anyone help me trouble shoot the problem? I don't want to have to start sendin parts back. I think its either the graphics card or the motherboard. I tried listing for beeps when turning it on and off but there was no beeps at all. Should i try reseeting CMOS?
System i bought which is now 600 quid cheeper!! ARGH! - http://www.overclockers.co.uk/showproduct.php?prodid=FS-041-OK
Hi, well first off you should get on the phone to OcUK tech support come Monday since its one of their builds to be honest, and im sure they will be able to advise. As for the price, yep the tech moves on quick these days...
