PC wont boot up
28 Nov 2002
Cumbria
I've found out it's the main harddrive thats causing the problem (I unplugged everything and replugged it in one by one until I found the cause)
When its plugged in to the sata port it won't boot and causes the pc to hang whilst detecting drives on bootup
Is there anything I can do bar sending it back?
its also got some stuff I backed up onto it the other day so I could reformat the laptop, :/ any chance of recovering anything?
checkm the sata cable isnt damanged its easy to do, try another cable.
I've checked all that, unfortunately it just freezes the pc right at the splash screen on boot up but the drive still spins so hopefully I can recover the backup of my laptop I made a few days ago :/
Cost: I guess it depends on how important the info you need to recover is? you can goolge for a IDE/SATA to USB cable as an alternative, I see these are available for less than £20 from A*m*z*n
Try using backtrack2 and a usb memory stick. Has worked for me when recovering data from many unreadable faulty drives...its free too :)
How will I go about using it?
The pc does'nt find the drive although the drive is still spinning (but not making any weird noises)
It also fails to boot with the drive plugged in and hangs at the splash screen when detecting drives
I've read it could be the circuit board on the top of the drive so I may swap it with my working drive and see how it goes (they are identical drives)
I'm not worried about the cash but I don't want to waste money on a bit of kit that may not do the job
If the circuit swap doesn't work then I may have to try a data recovery centre, anybody got any recommendations just incase?
Sorry about that it was late and wasnt thinking properly.
Thats would cause a problem if it was causing the pc to hang on bootup when connected :(
Well I have swapped the circuit boards and the drive is recognisable and gets past the splash screen but its now making clicking and whirring noises (it didn't do this earlier)
It's not recognised as a bootable disk so I borrowed a usb mem stick off my dad which had a cheeky version of xp which boots off it , it doesn't boot with the faulty drive attached though :/
