Short story, it got wet
Some water found its way into my pc after a glass was knocked over, the pc wasnt turned on at the time, i unplugged everything straight away, a few hours later i plugged the power on and as i should have known, nothing, no power what so ever, no mobo bleeps, nothing, the only thing that has life is the Blue CMOS switch on the back, the blue light is on when i plug in the power, i thought initialy that it was the PSU, because it is placed at the bottom of the case, but then i noticed the CMOS light, im pretty sure the water didnt get onto anything other than the PSU, but i could be wrong.
i dont know where to start with finding out where the problem is, having no boot at all, its rather annoying because im no expert.
Any help would be appreciated, thanks
,Some water found its way into my pc after a glass was knocked over, the pc wasnt turned on at the time, i unplugged everything straight away, a few hours later i plugged the power on and as i should have known, nothing, no power what so ever, no mobo bleeps, nothing, the only thing that has life is the Blue CMOS switch on the back, the blue light is on when i plug in the power, i thought initialy that it was the PSU, because it is placed at the bottom of the case, but then i noticed the CMOS light, im pretty sure the water didnt get onto anything other than the PSU, but i could be wrong.
