hey guys. this happened last night. heres my spec:
evga 680i
c2d 6600 @stock
bfg 8800gts @stock
2gb geil pc6400
i was playing around with the ram settings in bios just before this happened.may be related. bit too much of a coincidence otherwise. on power up, everything seems to power on but nothing is happening. the mobo makes no beep, all the L.E.D's come on and all the fans are spinning, just nothing comes up on screen. also, the digital onboard display shows 2 dashes which isnt in the mobo handbook. ive tried the ram in 2 different slots and tried one stick at a time. also tried resetting the cmos, although im not sure if i was doing this correctly and nothing has worked. really annoying. some advice desperately needed guys. thanks
evga 680i
c2d 6600 @stock
bfg 8800gts @stock
2gb geil pc6400
) then switching the PSU off at the back. Then what I do, is move the CMOS Juper over and leave it for about 30 seconds. Then I remove the battery, leaving the CMOS Jumper on reset. Then set it all back to normal, switch on the power and see if it boots.
