Hello All,
Not sure if this can be answered!
A friend turned on his PC last night and nothing happened...no fans spun etc (although PC case lights are on)
After going through all the normal checks (no loose cables, 1 stick of RAM etc).
I tried the power cables...turns out the PC turns on without the 8pin CPU power cable plugged in, although nothing on screen (so doesn't boot), but CPU fan spins etc?
A long shot, but has anyone else experienced this?
I assume it's either a Motherboard fault or possible PSU issue?
Any suggestions welcome!
Thanks,
Thanks,
