- 28 Dec 2004
- Bristol
After a recent update to oculus software, on switching my pc on it failed to boot windows properly the recovery menu came up and I was able to do a system restore. All good I thought.
The issue seemed to happen again following the update again so I though software issue.
Then after a couple more restarts pc wont boot at all. Just got stuck on bios front screen.
Now pc just restarts continuously but occasionally 1/100 boots fine and then stable
So I started testing. Removed ram and swapped some around. No change.
Removed gfx card. No change.
Removed other pci cards. No change.
Unplugged psu and tested voltages. All seemed fine.
Replaced cmos battery. No change.
Disconnected hard drives. No change
What are the next steps?
Thanks
Pete
Thanks
Pete
