PC wont boot
12 Jun 2004
Blackpool
Hi all,
My PC stopped booting this afternoon. Was built by myself around 18-22 months ago. No recent tinkering or changes.
Specs below
7800X3D
2x16GB Team group TCreate 6000Mhz CL30
MSI B650i Edge WiFi
RTX 4070 Super Founders Edition
2TB WD SN770
Corsair SF750
Fractal Terra case
Motherboard red and yellow LEDs light up for around 10 seconds before going off.
Fans spin as normal. Nothing on screen with GPU or onboard gfx.
I have tried:
Resetting CMOS via button on mobo io panel
Removing GPU
Removing SSD
Removing 1 stick of RAM
Testing each RAM stick individually in both RAM slots
Removing and resetting CPU
Replacing PSU
Nothing has helped. I took a picture of the CPU socket after removing the CPU and nothing looks bent or scorched.
My gut says CPU or RAM (both sticks?!?)
I'll likely try and see if I can attempt a blind BIOS flash. If that doesn't help I am open to ideas.
If it is the RAM you can bet I'll be refunded the £95 or so I paid at the time rather than sent replacements
It could well be ram, cpu or motherboard.
I could not see an LED area to say what has causing issues in the manual, does it have 1 at all?
Don't suppose you have another system or a friend you can borrow some DDR ram 4 from?
