Hi
I have a PC at work which is not working. We have a small network of 10 pcs. The PC does load to desktop and everything worlks fine apart from the fact it won't connect to the network or internet.
In the hardware device manager it says there are no problems and everything is working ok. However when i look in 'View network connections' on the problem pc it only shows 'internet connection' not the Local Area connection also which the other pc's do show as connected.
Any ideas what can cause this because i checked hardware manager and it said everything was working ok. We have reconnected all the wiring and changed the cables round to eleminate that.
Any help much apprecaited.
