- 20 Apr 2004
Hi,
Pretty much as the title says, my pc wont power on and im not sure where to start (I'm a bit if a noob when it comes to pc hardware failure!)
Basically, my pc switched off while it was idle. I didnt notice it for a few hours. Upon initial inspection it seemed that the power supply was dead. There was no status light on the mother board indicating that there was connection to a power supply and the PSU itself was very warm and didnt "smell too good"!
I picked myself up a new PSU. Connecting the PSU caused the green status light (named D2) on my ABIT IC7 motherboard the light up (as it should).
When the power switch on the PC is pressed a second red light D2 should light up indicating that the pc is powered up.
However, when i press the power switch on the PC, the red light flickers on/then off in a split second, the PSU makes a click like its about to kick in but then it stops. nothing on the motherboard starts up -P4 processor, fans etc.
I have tried removing/reseating components to no avail. I keep getting the same symptoms and i dont know how to move past this and investiagte further pinpointing a component at fault
I would appreciate as much input as possible into this eg possible causes, ways to identify faulty components
All help greatly appreciated
Damien
Damien
It sounds like a motherboard problem to me if not.
