PC won't power on?
13 Jun 2013
Just finished building my PC today, worked all fine and well. Installed windows 7 onto it.
After that I shut the PC down to put the backpanel and reconnect my Hard drive, and now after plugging the PC back in it does not get any power?
Help please :(
You checked to make sure the case button headers didn't pop out of the mobo? Easy enough to do. Sometimes wires get tugged when you put that panel on. Alternatively, potentially a short on the case?
The board usually lights up as does the power supply, now neither do and all of the case button headers are in place still.
What could be the cause of a short on the case?
Thanks
Got it working!
Took the motherboard ect out the case, booted it outside the case and it worked. Put it back in and it still works! Not too sure what the problem was but its fixed now :)
Thanks guys
