- 23 Nov 2005
- Kingdom Of Fife
Guys
I have a P35 DS4 (F11 BIOS) which is overclocked, my Q6600 G0 @ 3.2GHz and my RAM at 1066MHz prime stable 24Hrs. Anyway for some reason it does not like to be 'warm' resetted/rebooted, ie restart PC from, say Windows. If I do this it will start to boot, then power off, power on and power back on with BIOS defaults, ie default clockspeeds set for CPU and RAM! It's kinda frustrating!
At the moment the only way around it is just to totally power off then reboot!
I can't seem to work out what's going on as it is rock solid, in Windows with no other problems in 10 months!, from the OS or gaming! Any ideas?
The mobo manufacturer is Gigabyte, see sig for remainder of my rig!
Later,
Jonnygrunge.
Later,
Jonnygrunge.
