Hi all,
any ideas what could be causing this? I've dropped it off with the local PC repair man, but i'd really appreciate an insight to what it could be so I can figure out if I can afford a 2010 fix or if I am without Startcraft until January's pay day.
I've changed the cooler for a Coolit ECO liquid cooler, everything worked fine, I had about 6 hours gaming last night. I shut it down, then tried to turn it back on to check my ranks; damn thing won't boot up. CPU fan doesn't turn now either. I get power, all other fans are on, and I get two "fart noises" (not beeps) every 5 seconds, no display, just "fart fart". . . . . . . . . "fart fart".......
So I took it to bits and put my old fan cooler back in (surely it's the new hardware) nope, "fart fart" ... ...
So then I thought maybe it's a CPU fan problem, tried a different one, an 80mm 3 pin fan, and that started OK, but still no boot, not getting any display at all. So no 4 pin fans work on the CPU fan socket, but the small 80mm 3 pin one does.
Any ideas, I'm stumped and gutted.
Cheers all,
Shayne.
Cheers all,
Shayne.
A pea size drop is always enough.
