OK, I went to a friends house for a LAN and had to take my PC with me. When I got it there, it wouldn't boot up correctly, it would reach the Detecting IDE drives, detect them, then go to a blank screen. After a few reboots the PC started up as normal eventually for some strange reason and didn't have other problems with it during the night.
However, when I brought it home, I had another problem. I wire everything up again, then hit the boot button. Then all the components light up but then the motherboard speaker starts beeping continuously at 1 second intervals. The only way to shut it up is to give it a bash and/or switch it off.
I can't help but think its my RAM that is causing the problem, which I taken out and replaced in the same slots to double check for lose connections. But when on boot up, they merely have the middle orange light on, then go all on as if everything was OK, then go down to just the one green light.
If I do the slightest change, like take all the power off, remove a RAM chip then put it back in again, I seem to get a different boot up each time. Sometimes I have got the BIOS screen and managed to reset the BIOS, and even got it to run safe mode. But when safe mode started running, the system hung and I had to reboot.
Any help on why my PC is doing this and what I can do to fix it would be fantastic
Thanks
Alex
p.s. my system spec:
AMD 3800+ w/. Asus Star ice
2x 1GB Corsair XMS3200 CL2
ATI 256MB X850XT PE
Asus SLi-Deluxe Motherboard
Thanks
Alex
ATI 256MB X850XT PE
Is my GFX card dead?
