Hey was wondering if anyone could help me with a problem I'm having with my computer. I bought an iQon computer from Tesco last year which came with only 512 ram (-128 for the integrated graphics). When i came to upgrade it I purchased 2 sticks of 512 cosair value select DDR II 5300 667mhz memory from ebay. Having installed both sticks the PC simply failed to start up. However it works fine with only 1 stick installed. I ran memtest 86 on both sticks and found no errors so i assume the memory is fine. 5 calls to iQon's tech support resulted in been told it needs to be the right speed and if its the right speed it will start up, however it is the right speed and it isn't, he simply told me to take it to pc world to get someone qualified to do it. When i asked if it could be a timing issue it simply confused him and he started banging on about the speed again. So I was just wondering if anyone here has any ideas.
Theres the memory...
http://www.hardware.info/en-UK/productdb/bGNkaJiYmJTK/viewproduct/Corsair_Value_Select_PC25300/
and heres the motherboard...
http://www.msicomputer.com/product/p_spec.asp?model=RC410M-L&class=mb
